First post, by Chadti99
Or is there anything else out there I should look at?
C2G 50235 Select VGA Video Extension Cable VGA Male to VGA Female, In-Wall CMG-Rated, Black (1 Foot, 0.30 Meters) https://www.amazon.com/dp/B00CJRRY9M/ref=cm_s … ding=UTF8&psc=1
Reply 1 of 4, by maxtherabbit
if you're hell bent on using the passthrough, then yes that's your best cable option
personally I use an Extron VSW 2VGA A external 2 port VGA auto switch powered by my V2 SLI PC's power supply
the V2 passthrough can't handle the bandwidth of high pixel clock desktop resolutions (1600x1200, 1080p, etc.)
Reply 2 of 4, by Chadti99
Ah, how well does the auto-switch work?
Reply 3 of 4, by maxtherabbit
Chadti99 wrote on 2021-10-25, 15:15:
it's seamless, same UX as using the built in passthrough
Reply 4 of 4, by Chadti99
Nice I might give this a shot.
