First post, by bjwil1991
- l33t
I finally got around to working on the DataExpert OPTI495SX 3/486 VLB board (1 VLB slot) that I got from eBay that suffered the leaking battery issue.
I removed the battery a week ago and decided to give this thing a vinegar scrub down to remove corrosion (the keyboard controller socket needs to be replaced as most of the pins broke off) and gave it a bath (soapy water, rinsed with plain water, sprayed with DeoxIt D5, and 99.9% Isopropyl Alcohol).
Gallery of the board itself: http://imgur.com/a/ILtXlYw
Granted, the OPTi 495SX chip needs a reflow on the left side and I got the corrosion off (mostly, but it's better than before).
More to come: socket removal, inspections, trace repairs, and lots of testing.
