First post, by Galatea2.2
Enjoying this one, but having trouble maintaining low car damage in the championship mode.
Back in the day someone developed a car damage patch which could be used to edit a save game. The website still exists on webarchive:
http://web.archive.org/web/20050325184955/htt … nj/rallyfaq.htm
However the patch download link no longer works.
Does anyone either still have this patch, or know how to edit the car damage (e.g. what hex numbers to change)?
Reply 1 of 6, by zyzzle
I searched and searched for this patch ralfix2.zip but could not find it, either. I would like to revisit this game with the car damage patch fix also. Perhaps it was on an old BBS or compilation CD from years ago. As it was only a 9kb zip file, it may sadly be lost to time unless someone here can resurrect it by uploading it to this forum.
Reply 2 of 6, by Galatea2.2
Thanks for looking. Hopefully someone has it somewhere.
I've started comparing 'similar' save files in a hex editor to try and work out the bytes that control for damage.
However, in my case, there ended up being at least 21 altered strings (just after one race with same car etc.) so it's proving a bit tricky.
Reply 4 of 6, by vetz
Here you go:
http://web.archive.org/web/20001026224801/htt … oad/ralfix2.zip
If you need the other patches mentioned in the FAQ, then they are available here:
http://web.archive.org/web/*/http://gps.leeds … clnj/download/*
Click Here to download ralfin.exe (225K) This adds a Finnish flag (as in country) to the game. […]
Click Here to download ralnet.exe (235K) This is supposed to fix the time
problems in the network game and the Championship game. Yipeeeee!.
Click Here to download rallch.exe (235K) This allows the use of CH Pedals.
(English version)
Click Here to download raljoy.exe (234K) This fixes the non-analogue acceleration
and braking for joystick users. Only seems to be for the NON X-Miles version.
Click Here to download xmtcon.exe (28K) Converts your rallyc.cfg to rallyx.cfg so
you can keep your best times/saved games when you add the X-Miles addon.
Reply 5 of 6, by Galatea2.2
Excellent find Vetz !
This is great news - the game has some of the longest rally stages ever (approaching 60km in certain cases), so remove damage patch can be especially helpful.
Reply 6 of 6, by zyzzle
Wow! Good sleuthing, vetz! Internet archive has come to the rescue so many times, it's sublime. Where would we be without that wonderful, life-saving service? They're even better than Google, but I do wish you could search them like you can Google. As in, putting in a filename, keyword(s), date ranges, and / or logic, etc. Instead of just a single url.
