First post, by Anilocin
Hello Everyone,
I've been struggling to remove this AVC S478 heatsink as I'm trying to upgrade my P4 AGP test bench from 1.8 to 2.8 Ghz. Old forum pages state to push the two AVC-marked metal tabs down, yet the heatsink doesn't seem to loosen up. Any ideas?
Thanks!
Medion MD 9783
P4 2Ghz
i845D
512MB
ATI Mobility Radeon M6 32MB
W98SE/2K/XP Multiboot
P3 850Mhz
P3B-F
512MB
GF3 Ti200 64MB
SB Live! SB0060
Promise Ultra66
W98SE/XP Dualboot
P200Mhz
FIC PA-2005
32MB
CL-GD5446
Terratec Base-1
W98SE
Reply 1 of 5, by Doornkaat
Doornkaat wrote on 2021-01-25, 15:59:
It's a stupid mechanism. You need to press down on the large tabs to unhook them and then simultaneously pull the far out side of the large tab up/to the side so you bend the hook away from the retention frame so it does not hook in again when you stop pressing down on the tab.
You're not the first to have this problem.😉
Reply 2 of 5, by Doornkaat
You could also push on the tab to unhook and use a flat head screwdriver to pull the little hook from the plastic retention frame.
Reply 3 of 5, by Caluser2000
Anilocin wrote on 2021-10-29, 15:37:
Hello Everyone,
Thanks!
Which is correct. Prush them down and pivot back for them to disengage.
Reply 4 of 5, by Anilocin
Anyways, I have been able to remove the metal latches, with brute force I pushed out the tabs with two flat-head screwdrivers.
Thanks for the help! 😀
Medion MD 9783
P4 2Ghz
i845D
512MB
P3 850Mhz
P3B-F
512MB
GF3 Ti200 64MB
SB Live! SB0060
Promise Ultra66
W98SE/XP Dualboot
P200Mhz
FIC PA-2005
32MB
CL-GD5446
Terratec Base-1
W98SE
Reply 5 of 5, by Doornkaat
All is well that ends well.😉👍
