First post, by Snover
OK, I'm a bit perplexed. My guess is that this demo that I'm trying to run (Relais by Kolor) is just poorly coded, but when I try to run it fails to load glColorTableEXT and subsequently fails to run. This seems slightly bizarre to me, seeing as how it's quite recent (requires GF3+) and did work on my XP 1800+ with a GeForceFX 5900. Does anyone know of a test suite that will test glColorTableEXT?
Yes, it’s my fault.
Reply 1 of 14, by eL_PuSHeR
I have the demo "relais" by Kolor too and it DOESN'T RUN on my ATi Radeon 9600 anymore (I owned a GF4 Ti4200 previously, on where it run).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 14, by Snover
Un-fucking-believeable
glColorTableEXT
Selected NVIDIA GPUs: NV1x (GeForce 256, GeForce2, GeForce4 MX, GeForce4 Go, Quadro, Quadro2), NV2x (GeForce3, GeForce4 Ti, Quadro DCC, Quadro4 XGL), and NV3x (GeForce FX 5xxxx, Quadro FX 1000/2000/3000).
NV3 (Riva 128) and NV4 (TNT, TNT2) GPUs and NV4x GPUs do NOT support this functionality (no hardware support). Future NVIDIA GPU designs will no longer support paletted textures.
This is going to fuck up so much older stuff. 😒
OpenGL Extensions Viewer is useful for seeing what your card DOES support.
Yes, it’s my fault.
Reply 3 of 14, by eL_PuSHeR
Palleted textures support isn't good nowadays. But that doesn't seem to be an excuse. There are even some older games that made use of these extension (some older final fantasy?).
On the other hand, OpenGL extensions viewer is quite cool. For my ATi Radeon 9600 it reports 100% compatibility up to OpenGL version 1.5 (quite an improvement over my aging GF4 Ti4200). But I guess it's driver version related too. 😎
PS - We are talking about OpenGL API only. Does anybody know if Direct-X has some sort of fallback compatibility (even software emulated) for palleted textures?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 14, by Snover
Oh, that's it? Mine supports OpenGL 2.0 at 100%, nyeah 😉
= EDIT
Yes, it’s my fault.
Reply 5 of 14, by eL_PuSHeR
Mine too, but at 56% 😵
EDIT. Corrected the value. ATi Catalyst 5.3
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 14, by eL_PuSHeR
That's because your cards are newer generation = more expensive 😁 🤣
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 14, by eL_PuSHeR
I doubt it. Most newer games still fallback to some OpenGL 1.x for compatibility reasons. Even StarWars:KoTOR2 The Sith Lords uses OpenGL 1.4 - I finished it a week ago.
As for Doom3 I played it both under my GF4 Ti4200 and current ATi Radeon 9600 and played fine on both.
Now, it's probably right to think that some of the newest games may use some newer OpenGL 2.0 extensions (and more than games, demos). I don't know what would happen when you run them on a older card. They will probably switch to some compatibility mode still, or they may leave those new "bell and whistles" behind (advanced options grayed out?).
PS - As a sidenote, OpenGL is GREAT. I will never get accostumed to the behemoth slow Direct-X powered game engines (VALVe Source(tm) engine comes to mind). They are simply quite slow when compared to OpenGL, although there are always some exceptions that break the rule (although rare). Some other people say OpenGL is faster but Direct-X is more evolved and has better "eye-candy". I am not entirely sure.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 14, by Reckless
rofl
My rating of 12% for OpenGL 2.0 doesn't cut it then 😀 It's 100% up until that point... 4200 with 56.72 drivers.
Reply 12 of 14, by Snover
I find it rather strange that nVidia doesn't provide any kind of software conversion for glColorTableEXT to use pixel shaders, since I imagine that GL_EXT_palleted_texture was used quite a bit in the past.
Yes, it’s my fault.
Reply 13 of 14, by eL_PuSHeR
That's why I have stopped using nVIDIA cards. I think nVIDIA has done a poor work regarding their customers after TNT2. 😎
Intel i7 5960X
8 GB DDR4 (2100)
Reply 14 of 14, by Snover
GeForce256 was the most revolutionary video card of my generation...
Yes, it’s my fault.
