First post, by Joakim
I bought this soundcard because I was interest in the concept of pci-pci (sblink).
The attachment IMG_20211031_110855.jpg is no longer available
The attachment IMG_20211031_110901.jpg is no longer available
It seems to work but when I connect my Sennheiser headphones, the card is extremely noisy (as soon as computer starts up). When windows boots, the volume is extremely loud. I had to turn it down to <5% of the volume slider in windows 98se to get it to a reasonable level.
The noise is mostly white noise but also some digital beeps can be heard.
I have attempted to clean the card and the connectors, removed all other cards from the machine and tried different PCI slots. disconnected cd sound cable and the pci-pci cable. The motherboard I'm using is a msi6119 (440bx).
I don't know much about sound cards tbh, but I wonder if this can be due to bad capacitors?
BR J
Reply 1 of 17, by SScorpio
After you boot into Windows, open the sound mixer and mute all of the inputs. There should be at least a mic, line-in, CD-in, and on some cards PC Speaker.
Reply 2 of 17, by Joakim
Thanks but if I hear noise before windows boots I very much doubt it is fixed by a mixer setting.
Reply 3 of 17, by SScorpio
You said when it's in Windows you need to put it at 5% volume to be at a reasonable level. That means there's some massive amplification going on. Testing the mixer can be done in minutes for free, so I'm not sure why you don't want to at least try it.
You don't list what headphones you are using, just the brand. Do they have their own amp? Try connecting to the line-out rather than speaker output.
Reply 4 of 17, by Zerthimon
SScorpio wrote on 2021-10-31, 14:39:
This.
Reply 5 of 17, by zapbuzz
wireless mice can cause noise if you use one.
remedy for that is a extension cable to move it away 😀
Reply 6 of 17, by Tiido
This card appears to have a speaker amp on it that cannot be bypassed with jumpers like many other cards allow. That's where the excessive levels and noise come from.
Reply 8 of 17, by Joakim
Tiido wrote on 2021-10-31, 15:13:
I see. Could this be done by rewiring mods?
Reply 9 of 17, by Tiido
Yeah, it certainly is possible. The amp chip's inputs and outputs need to be identified, then this sort of thing done :
The attachment New Canvas.png is no longer available
Reply 10 of 17, by Joakim
Ok yeah I might just try something like that. The
amplification chip, KA2206CD, seems well documented.
Thank you
Reply 11 of 17, by Joakim
I was wrong when I said the chip is well documented, it is not.
For some reason my multimeter's continuity measurement mode is malfunctioning (no beeps) so I haven't been able to investigate this further.
Reply 12 of 17, by Thermalwrong
So uh, why not just connect a 3.5mm jack to pins 7 & 8 on the amp chip for left and right, then a ground from anywhere on the board?
Reply 13 of 17, by Joakim
Thermalwrong wrote on 2021-11-02, 21:41:
Oh, hmm. This is not obvious to me. Could you explain how you realized that pin 7&8 are the ones? 😀
Reply 15 of 17, by Joakim
Yeah I saw that but mine is called ka2206cd and has 16 legs, not 14, what am I missing here? 😀
Reply 16 of 17, by snufkin
Oops, didn't spot that I posted a link to the KA22066, rather than the KA2206. This is probably a better bet: https://pdf1.alldatasheet.com/datasheet-pdf/v … ETC/KA2206.html
Looks like they can come in 2 different packages, one with pins 4&5 and 12&13 joined together as a single pin, and one as a normal 16 pin dip. The 2206 datasheet (or at least one I looked at) doesn't even count them as pin numbers and has inputs on 5&8, which I think is pins 7 & 10 on the dip package. I'd guess the C is for the C version and the D for the DIP package. If your multimeter is still working for measuring resistance then you might be able to try tracing the amp output pins (2&15?) to the output capacitors and then to the 3.5mm socket.
Reply 17 of 17, by Joakim
Thank you for the schematics, I could not find them myself for some reason. Sadly my multimeter can't measure a known resistor value so I don't trust it anymore.. I will have to put this fix on hold until I get a new one.
