Tetrium wrote on 2021-11-03, 23:37:
Even the FSP Hexa PSUs have at least a plastic ring protecting the wires at the point coming out of the PSU.
The old 2xhalf rings were quite easy to go missing. It's possible it did in your case as well
I'll make+post photos of that later to illustrate
PSUs were supposed to be loaded within a specified way anyway.
And I seriously doubt that, as you are implying, FSP has been massively ignoring ATX design specs for many years now and only you are the very first person on this earth that saw through their devilish ways...
Most ATX PSUs do not keep ATX specifications, which are only a recommendation, not a law.
Fortron is no exception there.
The big difference is just their good marketing, building some reputation in the end user market, which causes (imho unjustified) trust into their products.
I just do not let trick me into this because I have actually tested these, which probably less than 1 in 10000 users do. Thus for me, Fortron has become category "noname", after I saw how bad they are.
Thus, there is no problem for the "bad manufacturers" because there is no knowledge about the technical implications that arise when using PSUs that do not keep voltages in spec. Users normally do not put a seemingly "working" PSU into closer observation.
For example, @pixelatedscraps recently invested much time to diagnose a non-functioning board, until he put into consideration to use a Seasonic PSU instead of a Fortron PSU, and bingo, all things turned out to work fine.
As I said, most times it works with voltages off-spec. But for example, some FSC PSUs which limit 12V overvolting, in return they reduce the 5V supply.
I think it is not too hard to understand that some 5V heavy boards will still (barely) work with, say, 4.1V, while others don't.
So users of bad PSUs do not even realize the damage it does to them by making them believe boards or other hardware is broken, and in turn they throw away perfectly good hardware, just because a bad PSU tricked them into believing this.
Isn't this sad?
You're pulling the trigger too fast and it's a shame because in a way I really like your way of testing and interpreting. And it's ok to make mistakes but only if you learn from them.
I just follow my personal criteria: the PSUs I use and recommend to use must be in spec, not damage things or cause bad side effects like the ones I described above.
BTW, this is also the reason why OEMs like HP, Dell etc usually use PSUs that keep specs, it is just a financial matter.
RMAs because of bad PSUs cause high cost.
Does anyone wonder why one never finds Fortron PSUs in computers of these companies?
Tetrium wrote on 2021-11-03, 23:37:I'm curious, was that PSU you mentioned as having had a heat death from a smoker or not? The fan from that PSU really seemed to have the telltale signs of one (it should be brownish and can be moderately sticky). Perhaps the fan has malfunctioned, it can seize up when the turning mechanism gets stuck.
No, it didn't look like smoker (no grime). It looked more like a PC that stood on the floor (the bottom of the room is the dustiest) in a corner of a carpeted room, collecting/filtering dust.
Tetrium wrote on 2021-11-03, 23:37:Yes, the voltages should be in spec, depending on what ATX specs the specific PSU was designed for and if the unit is brand new.
Output voltages are not dependent of age, they are dependent of circuit design.
Again, many manufacturers, particularly low-end ones, do not seem to care too much about the tight ATX spec, they care only about that the tolerances are in a range that limits RMA costs to a particular threshold.
It is upon every user to decide what (s)he wants and is willing to accept.
Some care, some care less, some don't.
Edit: And many just don't know. This is why some people including me try to make people aware, but there are too few.
