First post, by Mamba
The title says everything.
I know that it could be difficult to flash the HP board with programs (let me know if I am wrong), but I can force flash with a programmer.
The layout of the CUR-DLS non OEM is a little different, pin for front panel are different and in different location. Plus it has different RAM compatibility.
Should I be concerned?
Reply 1 of 6, by majestyk
If this is not a productive system, just try it and keep the original BIOS at hand in case you run into troubles.
Reply 2 of 6, by PC Hoarder Patrol
Mamba wrote on 2021-11-04, 21:15:
The title says everything. I know that it could be difficult to flash the HP board with programs (let me know if I am wrong), bu […]
Unless there's some specific problem you're sure an Asus BIOS cross-flash would fix, I wouldn't bother. The HP OEM board already supports both the max official cpu & memory it was designed for (2 x 1GHz Coppermines & 4GB of PC133 ECC SDRAM). If you're not already on it, you can get the latest HP BIOS (english version) from the Vogons Driver Library - https://www.vogonsdrivers.com/getfile.php?fil … menustate=30,29
If you need a different language version you can get it direct from the HP ftp server - ftp://ftp.hp.com/pub/servers/software/
The layout differences are minor - the front panel is just a simplified version of the standard 2 x 10 pin block...in the HP case it's a 1 x 6 (or 7) pin strip for Power On/Off/Sleep Switch, On/Off/Sleep LED & Drive Active LED. As for the RAM compatibility, although the HP documents state a max of 2GB (4 x 512MB) the board does support 4GB (4 x 1GB), although like most boards you'll only see between 3.25 & 3.5GB at POST. Both the ASUS & HP versions still only support ECC memory.
I was in a similar situation with another OEM version of the CUR-DLS, though mine was from a Fujitsu-Siemens PRIMERGY B210 server, but although I updated the BIOS when I got it I just used the latest OEM version from them with no issues and with the same hardware support.
Reply 3 of 6, by Mamba
Thanks for the reply.
Actually apart from compatibility issues and the front panel connection (where is the reset switch???), I was hoping to see an option to change the FSB (at least two possibilities, 100 and 133).
Is there a way to do so?
Modding a bios to that extent is far away fro lm my expertise.
Reply 4 of 6, by Errius
HP FTP server is down now? It was still up last year I remember.
ETA: OK working now; don't know why it wasn't earlier.
Is this too much voodoo?
Reply 5 of 6, by PC Hoarder Patrol
Mamba wrote on 2021-11-05, 08:30:
Thanks for the reply. Actually apart from compatibility issues and the front panel connection (where is the reset switch???), I […]
In your case the HP OEM board doesn't have a reset switch pinout (it's from a server after all !!) - not sure if you can still trigger a reset by shorting the two solder pads on the full 2 x 10 block (pic below) - if so you could maybe solder in a suitable pin header.
As far as the FSB is concerned, I believe there are two versions of this board (whether ASUS retail or OEM) - one has a blue switch block near the memory (may be slikscreened as CLKSW) for manual setting and the other version has no need for this switch block as it's auto-setting depending on the FSB of the installed processor(s), remembering that you'll need 133MHz memory for 133MHz processors or 100MHz-capable memory (100 / 133MHz) for 100MHz processors. My board is the auto-setting type so maybe yours is as well.
The attachment HP E800 FP Pinout.jpg is no longer available
Errius wrote on 2021-11-05, 10:46:
It was up earlier today on the above link - probably down for maintenance (they have multiple mirrored ftp servers anyway)
Reply 6 of 6, by Mamba
Thanks,
Actually I wanted to overclock 100Mhz CPUs to 133mhz.
Got a pair of SL5QV able to work at 1330mhz.
