First post, by Sphere478
I have this card, and on my other builds it’s been a godsend. It just speeds up the system and helps with booting issues all sorts of stuff, truly amazing card!
But my latest build, well, it’s giving me issues
This is a ali aladin V super socket 7 mobo ga-5aa
Normally when you hook up a sata drive to the promise card and put in a bootable cd the card takes over and automatically detects and boots the cd no intervention needed
But on this build it is detecting the drive, (tried multiple drives) it is detecting that the cd is bootable (tried multiple bootable cds) but at first it was hit and miss, now it won’t boot them at all.
I get to a part of the boot where it says something about checking bootable scsi and says ok, then goes to the next line and just sits there, normally that line is where like , setup loading, or whatever from the bootable cd would be but nothing..
I can get it to reliably boot the cd though if I unplug the hard drives from the tx4
What’s up with this?
Is there a firmware update for these cards? A setup I can enter to maybe change a setting? Not sure what’s up with this thing?
To make it even weirder, the hard drives worked fine on this card on the last mobo in this case.
Basically the one thing that has changed is the mobo. So I’m thinking the mobo has something to do with it, but what, I can’t say??
Sphere's PCB projects.
Reply 1 of 8, by Repo Man11
Have you tried a different PCI slot? It sounds like a resource conflict to me, so I'd also disable all unused hardware that you can in the CMOS settings, including the IDE port that you aren't using.
Reply 2 of 8, by luckybob
I've had mixed results with that exact card on non-intel chipsets. it gets better with newer chipsets, (P3/P4) regardless of the manufacturer.
Reply 3 of 8, by Sphere478
Repo Man11 wrote on 2021-11-06, 23:09:
i have disabled all unused items.
Should I go through and manually asign irqs?
It’s been about 15 years since I last did that, any tips?
luckybob wrote on 2021-11-06, 23:16:
430hx/tx worked fine so what you say tracks..
Have you discovered any tricks to making it work in your experiments?
Little bit of an update
None of the boot options that you can select in bios ide0, ide1, ide2, ide3, scsi, floppy, cd rom, ls120, etc seem to be what triggers the card. It’s the “try other bootable devices” yes/no that seems to be pointing at the card.
I can get the hard drive to boot if it’s plugged in (did a image from another conputer)
I can get the cd to boot if it’s the only device plugged into the card.
But never able to boot a cd if a hard drive is plugged in. But for a while it did, which is the odd part but not anymore.
Reply 4 of 8, by luckybob
My solution was to have a 2nd card. (and 3rd) #2 is based on the SIL3112 chipset. #3 I haven't used in a decade, a Promise based ATA-66 card and a matching ide/sata adapter.
Reply 5 of 8, by Sphere478
luckybob wrote on 2021-11-07, 22:33:
I’m always needing more pci slots in my builds it seems 🤣.
Reply 6 of 8, by luckybob
Sphere478 wrote on 2021-11-07, 23:36:
I'm only using 1 card at a time. silly.
That said, if I'm having a difficult choice between sata and usb 2.0, I toss in this card: https://www.newegg.com/siig-model-sc-unso12-p … 82E16815150027R The firewire has yet to be used, but I think its fun.
Reply 7 of 8, by Sphere478
luckybob wrote on 2021-11-08, 00:52:
That card is cool. i have the smaller version of it with all the via chips on it. Mine is glitchy as hell though, (common problem with them)
Reply 8 of 8, by Warlord
I prefer the SIL chips as well. Works fine once the right firmware is flashed. I've heard good things about promise controllers, but my general experience has been it either works great or it doesn't or is buggy and the drivers are hit or miss.
Firewire is a lot better than USB on older hardware, as far as CPU usage is involved. Its even better than IDE in that regard at least when i tested playing a DVD on a internal ide vs firewire dvd drive and the firewire had measurably less cpu usage.
Personally I'm not a fan of USB, it has its uses though. For transfering files I much rather use cat 5e. That goes for using printers as well, PCL over TCPIP is superior. Unfortunatly the best scanners are USB and thumbdrives can still be a thing so I cant completely get rid of usb.
