First post, by aigeek
ExpertMedia MED1600 is OPTI82C928 + AD1848
also with FCCID K2Y-AUDIO16C just like OPTI MAD16 82C928+ CS4231
Look good with WaveTable head and OPL3 clone IC
849.59 KiB
180.4 KiB
There are none factory driver on net
And it may suit with part of OPTI MAD16 82C928+ CS4231 driver,
it can boot on and setup the card
but in SNDINIT setup program,
8bit and 16bit digital sound test just begin then stop and report error.
The FM music test is OK.
In game such as DOOM2,
setup sound with SB will get no sound,
setup music with SB or adlib is OK.
Maybe the Codec IC AD90609/1848 is NOT been setup correctly?
Anyone can help with this card?
Reply 2 of 7, by aigeek
Schule04 wrote on 2021-11-08, 15:55:
Thank you. Yes I have tried it and got the results above. Not sure if it supports both CS4231 and AD1848 codec
Reply 3 of 7, by cyclone3d
Ok, so according to the soundcard-drivers.com archive, the original driver filename was 925d_w.exe
49.72 KiB
Trying to track down a copy now... I may already have it somewhere.
Edit: Looks like vogonsdrivers has a file named that:
http://vogonsdrivers.com/getfile.php?fileid=792&menustate=0
Should be the same as the file here I am guessing... file contents look the same as the soundcard-drivers page:
http://files.mpoli.fi/unpacked/hardware/sound … ip/_925d_w.exe/
Seems kinda sketchy since the file name indicates it is for the 925 and not the 928 but no harm in trying.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 7, by mkarcher
Everything you post about the behaviour points to an IRQ problem. If the test sounds starts to play, DMA and codec initialization work fine. The AD1848 chip only has a single interrupt pin, the OPTi pin is responsible for mapping the interrupt to the selected ISA IRQ pin. Try using a different digital sound IRQ. If that helps, check the ISA IRQ contacts for broken traces.
Reply 5 of 7, by Thermalwrong
Check out the Shuttle HOT-223, it's essentially that card, with the big ol' Opti 82C928 chip and an AD1848 codec:
https://archive.shuttle.eu/2004/de/223.htm
I tried out different drivers from mpoli.fi and found the set on this page (3.01) are the same as I'm running on my 386SX system. In that system, the card works perfectly with what I've tested it with so far. Really nice clean audio and doesn't need the -5v line.
Reply 6 of 7, by pc-sound-legacy
Beautiful and rare card! Opti aquired the sound department of OTI/OAK and the 928 is the successor of the Mozart card and OptIs first sound-IC. Therefore, I wonder if one of the expansion headers might be for the OPL4 add on that was planed but presumably never released. The other header is a waveblaster header but as far as I remember it is not mpu401 compliant.
