First post, by AlessandroB
Do kvm switches to connect multiple computers to a single monitor create a loss of quality in the visible video signal? Do you use them? tnks
Reply 1 of 5, by imi
in theory, yes. in practice, no... if it's a quality switch that is.
now there are some simple switchers out there that just have a rotary switch with a bunch of bare wire running between the VGA plugs... I wouldn't expect much from those.
Reply 2 of 5, by AlessandroB
the old kvm should have a mechanical rotary selector, that should induce little disturbance, what do you use?
Reply 3 of 5, by retardware
The loss depends on components' quality and signal frequency.
At 640/480 you maybe will notice nothing, at FHD you need a good quality KVM switch to keep loss acceptable.
Reply 4 of 5, by Unknown_K
You also need good shielded cables. Also depends if you are using analog signals (VGA) or digital ones (DVI).
Reply 5 of 5, by AlessandroB
i use vga signal in the classical retro resolution: 320x200 640x480 and 800x600, 1024x786 for win95/98/xp
