First post, by PC Hoarder Patrol
- l33t
Anyone have the lowdown on Tayeh caps?
Dug out a couple of my old BX boards (GA-BX2000 & Abit BE6) from storage for an occasional checkover - BX2000 is fine but the BE6 has an entire line of terminally blown caps, so recommendations for good replacements would be welcome.
The caps that have actually blown are all
6 x 1500uF 6.3V Tayeh LE Series (8 x 15mm)
Not blown, but probably ripe for replacement
7 x 1000uF 10v Tayeh RB Series (8 x 14mm)
There are also a number of smaller caps I'm not so sure need replacing which are
18 x 100uF 16v Tayeh MI Series
7 x 22uF 16v Jackcon
Can find any Tayeh datasheets, but I see posts online claiming that Tayeh / Evercon (GSC?) may be one and the same - certainly, the Evercon datasheets seem to cover the same Tayeh series I'm seeing on the board
Evercon LE Series - http://www.paullinebarger.net/DS/Everco ... Series.pdf
Evercon RB Series - http://www.paullinebarger.net/DS/Everco ... Series.pdf
Evercon MI Series - http://www.paullinebarger.net/DS/Everco ... Series.pdf
