First post, by Intel486dx33
How do you measure the size of computer case fans ?
Is it from screw hole to screw hole ?
Do you measure on a diagonal or straight across ?
Reply 1 of 5, by Nexxen
Borders.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- "One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
- Bare metal ist krieg.
Reply 3 of 5, by konc
...and if you only have the holes and want to determine what fan to get, measure the center of two holes of the same side. You can deduce the fan needed from that, for example if it's 7.6cm then you need an 8cm fan for this place.
Reply 4 of 5, by dormcat
konc wrote on 2021-11-14, 14:42:
Just measured three 8 cm fans; the distances of their screw holes are all 7.2 cm.
Reply 5 of 5, by BitWrangler
Some while back I was gonna improvise a VESA mount out of the frame of a 100mm fan with busted blades.... you can guess how far that went. 🤣
