First post, by sanuich
Hello everyone!
I have this motherboard
The first question i have:
what is the memory i shoul use for RAM?
this slits look unfamiliar for me.
If somebody can find the datasheet or manual for this board, please share. i will be appreciated.
Reply 1 of 2, by zyga64
You already have memory onboard in form of DIP chips. Probably 1MB. For 286 this should be sufficient.
If you want, you can upgrade memory by adding SIPP modules - U12, U13, U14, U15 (or 30 pin SIMM if you exchange sockets - they are pin compatible).
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 2 of 2, by Deksor
Here you go https://www.ultimateretro.net/fr/motherboards/3056
Could you please dump the bios ? Use this program in DOS http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
(It's limited to 64kb bios max but for a 286 it's fine)
