First post, by User Friendly
Ok I am getting this error when I try to run Master of Magic. I am running a AMD Athlon 64 3000, lots of ram n the like but this system wont run someone my fav games so I came acrossed DosBox which worked flawlessly for 1 day. Now I try to play it and keep getting this Exit to Error: CacheBlock Overrun. Is there anything I can do to fix this? If so please tell me
Reply 1 of 1, by eL_PuSHeR
Sounds like you are using an *older* version of DOSBox with dynamic core enabled?
You should try 0.63 (latest) or putting core=normal in your dosbox.conf file.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
