First post, by GabrielKnight123
I've got 16mb installed they are 4mb each and this 486 I'm working on has crash problems that look like bad ram from a garbled screen while gaming, I'll adjust wait states later but for now how do I test the ram, I'm betting there is no memtest86+ for dos or is there?
Reply 2 of 8, by 386SX
I remember testing 30pin SIMM 16MB (4x4MB) rams on my 80386DX 40Mhz with the bootable version and it ran great beside it takes a lot of time to finish the test! 😁
Reply 3 of 8, by GabrielKnight123
Thanks JJ I was trying to use version 5.01 but I got it working from your above topic with version 4.10
Reply 4 of 8, by kixs
For a quick check you can also use SpeedSys. It tests memory before doing memory benchmarks. I guess it's not 100% accurate.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 5 of 8, by maxtherabbit
Not to be pedantic, but either way it's not "for DOS"
All versions of memtest86 are bootable images that do not use DOS, version 4.x supports 386/486 and later versions require pentium
Reply 6 of 8, by GabrielKnight123
Max I tried version 5.01 as a bootable from a floppy that I had to make in Windows but it kept getting to the "Loading.........." screen then rebooting the pc but it might not be working from bad ram as when I used 4.10 it detected heaps of errors just before it crashed so I'm now up to testing one stick at a time
Reply 7 of 8, by maxtherabbit
GabrielKnight123 wrote on 2021-11-22, 14:39:
Right, that's because version 5.01 is not compatible with a 486. DOS has nothing to do with it
Reply 8 of 8, by 386SX
I didn't remember in facts how it booted the program and it make sense it's not a msdos boot but probably a more minimal way of loading itself. 😉
