First post, by Jed118
So I recently picked up an Epson Equity III+ 286 from Marketplace, and I had the owner POST test it. I basically got it for the monitor it came with, an NEC Multisync II, in good working order.
I decided today I will live stream me opening up the machine to see what's inside (I hadn't previously) and...
(in case you're curious)
https://www.youtube.com/watch?v=aRCpee3g3NQ
... the computer did and does work, I used it for many hours and left it on overnight to do a burn test. Amazingly what I found inside was functional:
This exploded and burned. The pin header plastic is melted in a few spots
It gets worse:
It looks like it took a s**t on the motherboard as well (original location of expansion card):
Soot, soot everywhere!
The charred remains of the culprit:
So, I have two questions to the community - What do these even do (I understand they smooth out dirty current, essentially) and what could the value of the capacitors (uF) be? My plan is to clean this up and redo the traces, as well as replace the caps. Computer works perfectly in this state!
What's for sale? my eBay!
Reply 1 of 2, by maxtherabbit
The SixPak 286 is a very nice card, hopefully you can get it repaired!
Reply 2 of 2, by Jed118
So I cleaned it up, the damage was much worse than meets the eye - there was burn damage all the way down to the fibre. The 286 will boot with it, but now it won't do a directory listing (hard crash as the DIR command is run) - everything else works, as long as you don't type DIR 🤣. And that's weird because at first, everything worked well. If you pull the card out, DOS will give you a DIR listing. I figure it's some DMA interference (a very charred SM cap fell off the card during cleanup) and really, there's no way to fix this without schematics and reference values for the components which were damaged.
The card will go on my wall for decoration - I have ordered two 512k ISA expansion memory modules, so about 1.6k of total RAM, which is enough for this old beast.
