First post, by Baoran
I have a 12 year thermaltake case that has a large fan in side panel. I am now looking for a new replacement for that fan. Original specs of the case say it is suppose to be 230mm fan but no measurement I have measured from the fan is 230mm. Spacing of the installation holes is only about 154mm both horizontally and vertically. I was looking at modern 230mm fans and came across bitfenix spectre pro, but it ended up beind 230mm x 200mm size and there was no info on spacing of the holes anywhere. Not even on the manufacturers site so there is no way of being sure if it would fit.
Anyone has any idea of a new fan I could buy as replacement that I could be sure of that it would fit in those holes in the side panel before ordering it? I just dont want to end up with something I cant install to it.
Case is Thermaltake VH6000BWS Armor+ from 2009 or 2010
Here is a image of the fan I found in an old review of the case. https://www.overclockersclub.com/vimages/ther … mor_plus/11.jpg
