First post, by Kotu Koylu
Today i got a Yamaha OPL3 sound card.Fm sound works perfect both in dos and windows 98.But midi music synt is sounds terrible.only basd sounds could be hear.
Bad caps or sound chip error?
Zida 5stx, pentium mmx 166, cl gd5430
Not any other card.
Reply 1 of 5, by Pierre32
Could it be an addressing error? What do your SETUPSA and Autoexec look like?
Reply 2 of 5, by Tiido
This card has no hardware MIDI synthesizer (Only OPL3L), what you get is Microsoft GS thing with WDM driver or Yamaha's softsynth with Yamaha's VXD drivers. Different driver versions have a different sound. You won't get MIDI out of this card from pure DOS, not without a MIDI addon card or an external module connected to driver.
I am unfamiliar with the sound of the game, try something like Duke 3D, then I'll know exactly what is going on.
Reply 3 of 5, by Pierre32
Here's what the FM intro should sound like: https://www.youtube.com/watch?v=NBZkCJKsFaU
OP appears to have the percussion but no other instruments.
Reply 4 of 5, by Kotu Koylu
i use this driver for dos(setupsa):
Re: OPL3-SAX in DOS
Then tried unisound and vanilla.almost in all games sound works but music is problematic.
@tiido
I know what all sound card uses software for emulate midi. i use midi word for MUSIC.
Reply 5 of 5, by Kotu Koylu
Just an update sorry for flooding.
Line out works perfect.Speaker out is problematic.I think the problem is amp chip or caps.Thanks for your helps
