First post, by duboisea
I have a IBM 60G0605 it is an ISA Ethernet card. For Windows 95 it uses the NE2000-compatible adapter, but I am not sure what IRQ and Port to use. It looks like a provided `CONFIG.EXE` allows me to adjust and determine the values? I found this PDF http://ps-2.kev009.com/pccbbs/options_iso/drvlist.pdf that suggests http://ps-2.kev009.com/pccbbs/network/etilan.exe is the binary I need. The only issue is that it requires a diskette drive.
I tried simulating a floppy drive using DOSBox `mount a $PATH_TO_DIRECTORY-t floppy -label disk1` and that didn't work. I tried using binwalk and it didn't find anything.
Anyone have ideas or suggestions? Is there another way/tool I could use to determine the IRQ and Port it is using?
