First post, by harry
Hello,
First of all apology if this question was already answered. I did a search but did not manage to find an answer.
I am running a dos application under vdmsound 2.0.4 (Win 2000 Pro). This application will go full screen, I can minimize it but then it will froze (even if I bring it to full screen after).
Is there a way to start directly that application in a Window (i.e. not full screen?)
Any hints/tips you could provide is appreaciated.
thanks
Regards
Harry
Reply 1 of 4, by DosFreak
NTVDM cannot run VESA programs in a Window, it requires Full Screen to access VESA on your videocard.
If you wish to use a program in a Windows that will not work in a Window under 2000/XP then you'll have to use a 3rd pary application, like:
DosBox
Virtual PC
Vmware
Solvbe
etc
etc
Make your games work offline
Reply 2 of 4, by harry
hey,
I am using already Dosbox and the likes... and was looking for a smaller footprint program...
cheers
harry
Reply 3 of 4, by DosFreak
The smallest out of those lists would be solvbe, depending on the application it can be kind of intensive tho.
Solvbe: https://sourceforge.net/projects/solvbe/
Also forgot to mention other emulators such as:
Qemu
Bochs
Reply 4 of 4, by Guest
thanks for the pointers.... will look into solvbe, the other emulators are fine but too heavy...
cheers
