First post, by CaelThunderwing
anywhere with Pre-flashed EEPROMs containing XTIDE? (looking to use it w/ the NIC i have for a Pentium based build im making. ) or anyway to patch the bios for an MSI MS5156 TX4 Rev 1.2? (theres downloads of the bios from https://www.mpoli.fi/files/hardware/ROM/MSI/index.html for 1.2 & 1.4 of the Bios)
Reply 1 of 1, by waterbeesje
Most network adapters allow to program a blank chip so it's pretty easy to do it yourself. Just make sure the type of chip you want to use is supported by the card.
Stuck at 10MHz...
