PARKE wrote on 2021-12-20, 13:21:
The rows do not always follow the same orientation but can also occur 'flipped' vertically.
True, but you can just see the 'G' silkscreen mark for the bottom row, so I think that tells you that row's 'T' arrangement, and the other rows can be seen more easily. Plus I think it fits with what can be seen of the PCB traces on the other side.
At the moment, if I'm right, then there's a jumper on the top row between C3 and B1, which I think means that any LED that should only be on when Low is selected (like top row G) will always be on. My guess is that the display is stuck on 200.
