First post, by watz
Hi!
I managed to revive a scrapped and severly damaged ASRock 4CoreDual-VSTA and it works great. However I'm getting the dreaded "MAC adress invalid in both CMOS and flash" Bios message. There used to be a MAC tool that people used on this exact board to set the MAC address and fix this error. However, all links to this tool that I can find are dead. The MAC tool that you can download from the ASRock website does not work on this board (just prints "unsupported").
Sure, I could probably disable the onboard LAN and live without it But I'd rather like this last issue to be fixed.
Does anyone of you have the matching tool for this board? Alternatively, a dump of the flash should also work for me.
Thanks!
Marco
Reply 1 of 3, by PC Hoarder Patrol
watz wrote on 2021-12-23, 00:26:
Hi! […]
Hi!
Thanks!
Marco
Is this the one
The attachment 4Core_MACtool.ZIP is no longer available
Reply 2 of 3, by watz
Worked perfectly, thanks a lot!!
Finally no more error message at boot. Even with the integrated NIC disabled it would pop up and needed F1 confirmation. And there wasn't any "halt on errors" option that I could find either.
The board came in a pile of scrap, had the expected couple dozens of bent CPU socket pins, two exploded MosFETs, broken NB die edges, ripped out caps and corrosion everywhere. I did not expect it to POST after repair, but it did. And most surprisingly, all RAM slots work, AGP and PCIe work. Its a survivor!
Reply 3 of 3, by TrashPanda
watz wrote on 2021-12-23, 11:32:
Give her a good home it sound like she has earned it too !
