First post, by Jackal1983
The board in question is the SL-B7A-F, its an ITX (sort of, it's a bit wider, but fits in an ITX case) sized board that came in some of their QBIC SFF Barebones PCs (EQ3705, EQ3702-250). Everything seems mostly standard, except for the front audio header: its a 2x6 (12 pin, with pin 12 the key) header, with grounds (3 of them on pins 2,3, and 10) that don't really line up with AC97 or HD Audio. I've dug through internet archive for a manual with no luck. Anyone have any experience with this thing, or know where there's an archive? I though I could work it out using wiring colors (found a couple of decent resolution pics of the cable) but it seems like those aren't standardized. The cable seems to carry Mic, Headphone, and digital audio out signals.
Reply 1 of 2, by PC Hoarder Patrol
Jackal1983 wrote on 2021-12-23, 08:01:
Manual and extract attached
The attachment Soltek SL-B7A-F JAUD1.jpg is no longer available
The attachment Soltek SL-B7A-F.zip is no longer available
Reply 2 of 2, by Jackal1983
PC Hoarder Patrol wrote on 2021-12-23, 10:00:
Manual and extract attached […]
Soltek SL-B7A-F.zip
Freaking awesome dude, Thanks!!!
