First post, by feltel
In a stash of old computer equipment I found a MS-4145 mobo with serious battery damage. I always looked for a 486 PCI board as I had back in the 90ies. I cleaned the board as good as I could and tried powering up. But it is dead as a doornail. To be fair, it has the most extensive battery damage I ever encountered. The board served as a parts donator some time ago as it looks like.
1.46 MiB
696.18 KiB
1.83 MiB
1.42 MiB
I checked the BIOS chip and it is good, it reads correct in the eprom programmer. So this cause of error is ruled out. I found this thread Testing the waters with a 486 - MS-4145 board repair with a similar damaged MS-4145, but the thread ends without a message of success or failure.
558.49 KiB
I'd like to ask if this is worth a try or is it waste of time.
Reply 1 of 5, by Paadam
It is a very good board, I had one (also dead) and Tiido repaired it. It had permanent reset which ended up being caused by dead chipset. After replacing it worked nicely.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
Reply 2 of 5, by kikipcs
I also have one! (and it's corroded as hell too). I am the author of that thread - frankly I shelved the project for some time due to a severe lack of skill in electronic repair & soldering but now that I'm less mediocre at it I might actually get back to it.
It has the last ALi chipset (486 FINALi), with great performance. FPM and EDO support, also supports a lot of Socket 3 CPUs. Integrated KBC with PS/2 mouse support. All that makes it a good little late 486 board. Also has the AMI WINBIOS if you're a fan of it!
A word of encouragement: In your case the corrosion is not as bad as it potentially could be. My research on this thing so far has led to the finding that the affected areas are responsible for the onboard peripheral connections, like the HDD, FDD etc; the (unused, since there is an integrated one) KBC controller circuitry; the power circuit, and a few traces go to the CPU socket, memory port, and PCI and ISA slots.
A lot of the damaged traces/components can be essentially left alone - I have confirmed with MSI that the SMD caps/resistors right under the barrel battery are not necessary for the board to work, same goes for the unused KBC circuit. As long as you restore the most vital traces and reinforce the power circuitry you might make it boot; then you could focus on reworking the onboard peripheral circuitry etc. The 74F04 might need looking at too - mine was so eaten that only 3 of the pads survived.
It's a lot of work, though with enough elbow grease anything is possible. Take for example Necroware on Youtube - the man has repaired a lot of boards in a similar state.
Best of luck!
Reply 3 of 5, by feltel
Thanks for your words of encouragement. I`ll follow traces and tone it out as good I can, but I fear I will not have enough diagnostics skills to tackle this board. I even thought about contacting Necroware, as he is -like me- from Germany to the best of my knowledge. Maybe he's interested to make a video about it.
Reply 4 of 5, by mpe
I also own this board. When dealing with damage like this, it is important to desolder components in the area and inspect damage under those parts.
In your case that means HDD/LPT/COM/FDC connectors, the power connectors and potentially also both SIMM slots. This is to clean it and also importantly to be able to trace continuity when troubleshooting.
Blog|NexGen 586|S4
