First post, by DosFreak
I'm trying to get Autoexec.nt and config.nt to be protected files under Windows XP but it's not working.
Now I have an MS KB that states that if you place a file in dllcache and then reboot, upon the next boot the file will be protected. This is only stated for Windows 2000 though and NOT for Windows XP.
I plan to test out 2000 WFP in a bit but really this is for all those XP users out there who have the 16-bit subsystem problem.
So far I've placed the files in dllcache, but they are not protected, currently I'm running SFC to see if that may update XP's list but I'm thinking that it may already have a set list that it goes by.....probably in SFCfiles.dll. Anyone know for sure? Will I have to hax0r sfcfiles.dll?
Reply 1 of 5, by DosFreak
It's likely that it is SFCfiles.dll and if it is and even if I could put autoexec.nt and config.nt in there this would not be a solution for everyone since you just can't share out Microsoft files...sigh....perhaps I should contact MS and tell 'em to push down a fix. The lazy bastages.
Make your games work offline
Reply 2 of 5, by DosFreak
http://www.microsoft.com/resources/documentat … t3/proch18.mspx
Backup considers the functionality of WFP when backing up and restoring boot and system files. System files are backed up and restored as a single entity. The WFP service catalog file, which is located in the folder %systemroot%\System32\catroot\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}, is backed up with the system files.
Reply 3 of 5, by DosFreak
WFP protects system files by detecting attempts to replace protected system files. This protection is triggered after WFP receives a directory change notification for a file in a protected directory. When WFP receives this notification, it determines which file has changed. If the file is protected, WFP looks up the file signature in a catalog file to determine if the new file is the correct version. If the file version is not correct, the system replaces the file with the correct version from either the cache or distribution media, depending on whether the file is located in the cache. WFP searches for the correct file in the following order:
Reply 4 of 5, by HunterZ
When I used to bother using VDMSound to run DOS games in the NTVDM instead of DOSBox, I remember that I often had to customize my AUTOEXEC.NT and CONFIG.NT files to make various games work. Wouldn't protecting the files make this much harder to do? I guess Windows and VDMSound both let you specify alternate .NT files to use, but lots of people probably won't bother to figure that out before coming here to ask about it...
Reply 5 of 5, by DosFreak
Nah, you just modify the config.nt/autoexec.nt in the SYSTEM32 and DLLCACHE folders instead of just the one folder....just like any file today that you want to replace/modify but Windows replaces.
