First post, by Skelefits
I’ve got two motherboards I’d like to try to repair.
The first is a Fuyu 20V0 with an embedded AMD 386 DX-40.
The attachment IMG_20211229_105946.jpg is no longer available
The attachment IMG_20211229_105956.jpg is no longer available
The attachment IMG_20211229_110011.jpg is no longer available
The attachment IMG_20211229_110027.jpg is no longer available
I’ll remove whatever is socketed and then use a soft toothbrush to give a surface level clean with white vinegar. I’ll follow the vinegar with 99% isopropyl alcohol.
Next I’ll place the board in an ultrasonic cleaner with distilled water. After that I’ll desolder whatever looks damaged and go from there.
Is this a good starting procedure?
The other board I’ve got is a Socket 7 SD-P5TA. It has green stuff on it, but I’ve got no idea where it came from. Nothing looks wrong with the battery holder.
The attachment IMG_20211229_110102.jpg is no longer available
This one looks painful as there are a bunch of surface mounted resisters. Two are so corroded I can’t tell their values.
Reply 1 of 3, by Horun
🤣 looks like a cricket or micro mouse parts caused it. Had a mid tower a mouse climbed thru an open ISA slot in back and pee-poo all over the side of the board....
corroded it badly... funny now but not back then...
Reply 2 of 3, by BitWrangler
Hope the fuyu isn't an f.yu .... I <3 those mini 386 boards... before mp3 players, it did cross my mind to build one into the dash of a car to play mods
Reply 3 of 3, by Skelefits
Horun wrote on 2021-12-29, 02:18:
That must be it. I found the board in a plastic bag in the shed.
I realized today that my two 86 computers would also have batteries in them, so I rushed down to check. A tower with a Faraday FE2010A chip had a leaking battery, but it doesn't seem to have reached the board. It does have corrosion on an ISA and co-processor slot though. The board seems to have some kind of finish of the PCB. It looks like it would be really nice to work with.
The attachment IMG_20211229_230111.jpg is no longer available
The attachment IMG_20211229_230134.jpg is no longer available
I also have a portable suitcase 86 but haven't check it yet. I haven't previously had any luck taking it apart.
