First post, by G_Phrase
I have gotten to here when I got a problem
"Please consult the documentation of your game for which file is needed to start the game. In the case of Test Drive, it's TDCGA.EXE. So now, I just type this:
TDCGA.EXE
That's it! Here's a picture of all of the commands I've written about in Step 2"
I typed this in and the game wont load. What am I doing wrong?
Reply 1 of 5, by eL_PuSHeR
Run TD.EXE instead.
PS - If it doesn't work you should WRITE DOWN ALL THE DETAILS. Otherwise we won't be able to help you. We aren't seers. 😈 😠 😒
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 5, by Ninyin
Thx, but it doesnt work. Everytime I say something.exe , my Dos-Box will say Illegal Command.
I have v.0.63
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
What is the output from
dir TDCGA.EXE
and
dir TD.EXE
_________________
Reply 4 of 5, by avatar_58
Don't type ".exe" at the end. Simply TDCGA or TD
Reply 5 of 5, by HunterZ
Sounds like you're either not mounting the directory correctly, or not changing to it.
