First post, by GabrielKnight123
I have a problematic 9 pin serial port COM A on a 486 motherboard so I'm going to make a loopback cable and use AMIDiag but I see there are a few ways to make one from different pin wire connections, in my book it says to connect pins:
1 to 7 to 8
2 to 3
4 to 6 to 9
The above is for a standard IBM type 9 pin serial female DB9S and a web site https://ardent-tool.com/misc/wrap_plugs.html says different and I dont understand the diagram which one do I use?
Reply 1 of 4, by snufkin
Are they different? From ardent-tool:
DCD 1 -----+-- 7 RTS
+-- 8 CTS
RXD 2 -------- 3 TXD
DTR 4 -----+-- 9 RI
+---6 DSR
Which looks like 1 to 7 & 8, 2 to 3 and 4 to 6 & 9, same as your book?
Reply 2 of 4, by BitWrangler
I would assume the IBM one is correct for IBM diagnostics, but other diagnostics have their own ideas...
https://airborn.com.au/serial/rs232.html
https://www.epanorama.net/hwbooks/cable/loopb … ck9checkit.html
Reply 3 of 4, by TheMobRules
I use this one with CheckIt.
Reply 4 of 4, by GabrielKnight123
Argh wrong web site sorry its been a 21 hour stretch but the site I saw had different wiring
