LeFlash wrote on 2022-01-05, 07:36:
Thanks for the link! I was seraching a lot, but didn't find that.
Do you have a photo of the connector under P3 (called P4 in the text)? It seems to be the culprit of the problem, there are some wire bridges according to the photo!
(https://www.os2museum.com/wp/wp-content/uploa … 09/P9197758.jpg)
Sorry, no I don't and I can't find a better picture than the one linked. However, if you look at the various docs for the SBT2 and the SC5000 you can get both the motherboard pinouts and chassis front panel cable schematic, so I knocked up this quick extract from there - think the only difference is that the cable for the intrusion switches is also connected to P4, but wasn't supplied in the linked picture. Also, I'm guessing P2 is the reset switch (1M7)
The attachment SBT2 Front Panel.jpg is no longer available
