First post, by Dusko
Hello All!
I just added this motherboard to my collection and can't find the manual or any info about it online. Does anyone has this motherboard's manual?
Biostar MB-8500TEC ver3
I found some other variants of the 8500 series online, but the jumpers aren't the same.
    1.89 MiB
https://www.youtube.com/@myoldpc9458
Reply 1 of 27, by Repo Man11
That's a tough one - this capture of the Biostar USA page skips right over that model; maybe it wasn't sold in the US, or was OEM only? https://web.archive.org/web/19970620073836/ht … pd/products.htm
Reply 3 of 27, by Dusko
Repo Man11 wrote on 2022-01-09, 06:40:
Yeah, super weird, I was looking in WayBackMachine too, but didn't come across the link you shared. Good to know, Thanks.
I got the board for cheap so I didn't bother trying to find the manual first.
I have no idea if it was OEM or what since I got it on eBay.
Thanks again!
Reply 4 of 27, by Dusko
PC Hoarder Patrol wrote on 2022-01-09, 07:05:
Try here (includes v3 specific jumpers) - https://web.archive.org/web/20010209101446/ht … EC/menutec.html
WOW!! How did you find it??, I was looking all over and nothing. VOGONS community is just amazing!
Thank You!!
Reply 6 of 27, by Dusko
PC Hoarder Patrol wrote on 2022-01-09, 07:21:
Dumb luck & pixie dust 😀 - happy to help
Lol!!
Just in case the link disappears, I made a doc file in case someone needs it one day!
    MB-8500TEC v1-2-3.doc
    20.27 KiB
    40 downloads
Reply 7 of 27, by Dusko
Bios file v4.50PG
Reply 8 of 27, by Doornkaat
Dusko wrote on 2022-01-09, 07:26:
Lol!!
That's good thinking. Kudos!👍
Reply 11 of 27, by Dusko
computerguy08 wrote on 2022-01-09, 11:04:
Dusko wrote on 2022-01-09, 08:06:
Bios file v4.50PG
Awesome board you found there. Added it to UR.
https://www.ultimateretro.net/en/motherboards/10195
Awesome!. Keep in mind that I modded it adding a socket for the Odin RTC. If you look closer at the picture, the RTC looks a bit higher than it should.
I have around 10 more socket 3 and 7 motherboards in my collection, PM me if you are interested.
Reply 12 of 27, by Dusko
snufkin wrote on 2022-01-09, 12:31:
Possible updated BIOS (Oct 26th 1998) here: https://web.archive.org/web/20030415205633/ht … 500tec_bios.htm
Yes, that looks about right. I haven't tested it yet though.
I did search there but it didn't show up. What was your search keyword?
Reply 13 of 27, by Dusko
There are more jumpers that are not documented and some have charts printed on the board:
Jumper# / Pins / Current State
JP1 (4) 3-4 (No info)
JP2 (4) 3-4 (No info)
JP5 (3) 1-2 (No info, might be the Bios voltage as per continuity test: 5v / 12v)
JP10 (3) 2-3 (Tage Size, as per chart printed on the board)
JP11 (2) Open (No info)
JP12 (3) 1-2 (L2 size, as per chart printed on the board)
JP13 (3) 2-3 (L2 size, as per chart printed on the board)
JP14 (2) I wasn't able to find this jumper (Pipeline, as per chart printed on the board)
JP19 (6) Open (No info)
JP20 (4) Hard Wired ((No info, might be CPU Voltage)
JP22 (3) 1-2 (No info)
JP27 (3) 1-2 (No info)
See attached doc with updated info.
Reply 14 of 27, by Horun
Great work ! You are the archive master 😀
Dusko wrote on 2022-01-10, 03:55:
Curious What format is that .doc ? Cannot open it for some reason using MS Office or Wordpad (win7). Hex edit shows PK as the header so is it zipped ?
Reply 15 of 27, by Dusko
Horun wrote on 2022-01-10, 04:30:
I use Libre Office. Here is a zipped docx file, let me know. Thanks
Reply 16 of 27, by Horun
Thanks that opened ! Yeah I usually just save the archive pages as .HTML and then quick edit to add/fix. Think any computer from Win9x up can open a .html if it has no java or odd stuff...
Reply 17 of 27, by PC Hoarder Patrol
Found reference to a couple of older BIOS versions here - https://web.archive.org/web/19990220172430/ht … ec/tec-bios.htm
Looks as if your original was TEC0607.BIN from June 7 1995 (sadly no trace of TEC0831.BIN)
Reply 18 of 27, by Dusko
Interesting! It looks like the "newest" Bios version is i01bw429.bin, as previously posted by snufkin.
I still haven't test the Bios, will report back when I do.
This is an odd motherboard, it may be one of the earliest socket 7 that Biostar made. It doesn't have a ps2 mouse port which I find odd for a socket 7, and very limited CPU support.
