First post, by 386SX
Hello,
I'd like to ask you which are the exact measures "coordinates" to make the AT keyboard hole in a full metal ATX shield by ourself, for example starting from the right corners of a classic atx metal case shield place, measuring to find the exact center of the AT keyboard connector and begin to drill the metal. I know I might make it simply installing the mainboard and saving the point where to make the I/O shield hole but I wanted a precise hole without removing too much metal on the side of the new I/O shield to adapt an AT mainboard into an ATX case.
Thanks.
Reply 1 of 2, by rmay635703
Hmm, I had a stack of 20 AT plates for use in ATX cases
Now where were they?
Next if memory serves AT io plates weren’t all the same some swung in with a bolt and others popped in and not all those that popped in were the same size
Fun
