Voodoo connection cable
Reply 20 of 24, by Doornkaat
Meatball wrote on 2022-01-27, 13:19:
Doornkaat wrote on 2022-01-27, 13:17:
Meatball wrote on 2022-01-27, 12:59:
Video corruption. Games from Rage exhibit this (Expendable, for example). In some cases, the card may not run at all above 133mhz bus. 100mhz is the safest max FSB. I think even running the Voodoo 1 on a CPU over 400-450mhz will cause these problems.
Depending on the individual card issues arise much earlier. I have one that does not work with FSB speeds of more than 66MHz and crashes when the CPU speed is above ~333MHz.
Hmm… I wonder if my Canopus Pure3D 6MB has this issue. I will try it on a PII 233 and see how it goes. Thanks for the tip!
The card with the issues is an early Guillemot MaxiGamer 3D. I guess either the early Voodoo Graphics chips or the early PCB are at fault. Just speculation though. 😅
Reply 21 of 24, by atom1kk
I have here also a P1 200 MMX machine which would suit perfect the V1 but I dont know switching always the systems under my desk, than I would have 3 machines 😁. Beside, if I decide to use the P1 machine, it has a 3d rage pro onboard. is it a good card for 2D/3D (except Glide) gaming? Have here also a S3 trio 64V+ card.
Reply 22 of 24, by Meatball
atom1kk wrote on 2022-01-27, 14:13:
The Rage 3D isn’t a great DOS card, but the Trio is. However, with the Rage Pro 3D, you can play the original Tomb Raider in Windows without DOS and the MechWarrior 2 ATI version, among a few other games. There’s a thread here about this:
Proprietary 3D API's
***->WINNER, 1ST PLACE<-***
2022 #QUAKE3totheMAX -560.5fps-
Brain Drain Retro LAN https://discord.com/channels/799008837918261328
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
DDR@411MHz (2-3-3-3)
GeForce 256 DDR@144/344MHz
ESS Maestr0-1
Reply 23 of 24, by atom1kk
I am thinking about now to start this Project, because i just analyzed and all games i need to have win 98 are until the year 98. All other games i can play well on my main machine with good compability, so due to place issues i am thinking to ditch the P4 because there is kind of no necessary for that and stick to the P1. As i remember i startet with a P1 100 And since than I was always using ATI cards. What would be the best suit for the p1 200. I mean it should also have a good 2D performance and have the Direct 3d compatibility. i think from that Time a riva TNT 1 or 2 would be a good choice or? it must be a pci card. the board has no AGP
maybe i open up a ne topic for that:D
The V1 is still to come than.
Reply 24 of 24, by Meatball
atom1kk wrote on 2022-01-27, 15:02:
Take a look at this exhaustive benchmarking work from The Serpent Rider:
PCI Video cards benchmark: Electric Boogaloo Edition
Windows ME
NForce2 A7N8X-E DLX
Athlon 848/154MHz
ESS Maestr0-1
