First post, by Hanamichi
I've been wanting to attempt this for a while or someone smarter hopefully do it for me 😁
Got a bit of time at work today so get the ball rolling..
Some people mention a mythical ATI Catalyst 6.5 Beta that has ME drivers ... well here it is below...and of course it's intended for 2000/XP.. end the myth:
https://www.guru3d.com/files-get/ati-ca ... ta),4.html
Now the last genuine ATI Catalyst for ME/98 is 6.2 Here:
https://web.archive.org/web/20070914013227/ht … onaiw-98me.html
A few options I can think to get this to work in a hacky way:
1. Edit the inf of Catalyst 6.2 to include new cards from a newer driver inf
- Copy and edit the PCI VEN strings
- Merge reg settings from 6.5 for newer cores?
2. Copy accross all the 2K drivers from Catalyst 6.5 and fool the Catalyst 6.2 installer into using them
3. Hack the Catalyst 6.5 installer to work on 98/ME OS
- this site maybe of use: https://tylerapplebaum.github.io/setupinxhacking.html
(1) seems the easiest
Regarding the key inf files for install I noticed:
Registry Settings
In Catalyst 6.2
R6_Common_AddReg - is where most of the key settings are for registry entries and is universal across most cards we care about.
I notice between R481 X850 and R420 X800 there is one difference to the install:
R481 uses "R481_AddReg" - mainly seems to do with the DVI TDMS settings.
In Catalyst 6.5 the format changes... most of the key registry settings are combined into a specific core settings list:
ati2mtag_R520_SoftwareDeviceSettings
ati2mtag_R580_SoftwareDeviceSettings
etc.
Perhaps a merging of the 6.5 and 6.2 reg settings is needed for these newer cards.
Device IDs
A quick hack to add the VEN DEV and SUBSYS ids for X1X00 cards to also install as a R481..
E.g. "Radeon X1900 Series" = R481_ENU, PCI\VEN_1002&DEV_7249
I edited : C7_30314.INF within the 6.2 catalyst directory.
I have attached but had to rename the file to upload. So set it back to being .inf if testing.
Standard stuff so I guess plenty attempted this already.
Looks like this:
"RADEON X850 Series    " = R481_ENU, PCI\VEN_1002&DEV_4B4B
"RADEON X850 Series - Secondary" = R480_ENU, PCI\VEN_1002&DEV_5D6D
"RADEON X850 Series - Secondary " = R480_ENU, PCI\VEN_1002&DEV_5D72
"RADEON X850 Series - Secondary " = R481_ENU, PCI\VEN_1002&DEV_4B6C
"RADEON X850 Series - Secondary " = R481_ENU, PCI\VEN_1002&DEV_4B6B
"RADEON X850 Series - Secondary " = R481_ENU, PCI\VEN_1002&DEV_4B69
"RADEON/MOBILITY 9200" = M9Plus_ENU, PCI\VEN_1002&DEV_5C61
; Hanamichi Edit Below
"Radeon X1800 CrossFire Edition" = R481_ENU, PCI\VEN_1002&DEV_7109
"Radeon X1800 CrossFire Edition Secondary" = R481_ENU, PCI\VEN_1002&DEV_7129
"Radeon X1900 CrossFire Edition" = R481_ENU, PCI\VEN_1002&DEV_7249
"Radeon X1900 CrossFire Edition Secondary" = R481_ENU, PCI\VEN_1002&DEV_7269
"Radeon X1900 GT" = R481_ENU, PCI\VEN_1002&DEV_724B
"Radeon X1900 GT Secondary" = R481_ENU, PCI\VEN_1002&DEV_726B
"Radeon X1900 Series Secondary" = R481_ENU, PCI\VEN_1002
"All-in-Wonder X1800XL" = R481_ENU, PCI\VEN_1002&DEV_7109
"All-in-Wonder X1800XL " = R481_ENU, PCI\VEN_1002&DEV_7109
"All-in-Wonder X1800XL Secondary" = R481_ENU, PCI\VEN_1002&DEV_7129
"All-in-Wonder X1800XL Secondary " = R481_ENU, PCI\VEN_1002&DEV_7129
"All-in-Wonder X1900" = R481_ENU, PCI\VEN_1002&DEV_7249
"All-in-Wonder X1900 " = R481_ENU, PCI\VEN_1002&DEV_7249
"All-in-Wonder X1900 Secondary" = R481_ENU, PCI\VEN_1002&DEV_7269
"All-in-Wonder X1900 Secondary " = R481_ENU, PCI\VEN_1002&DEV_7269
"Radeon X1300 Series" = R481_ENU, PCI\VEN_1002&DEV_7142
"Radeon X1300 Series " = R481_ENU, PCI\VEN_1002&DEV_7146
"Radeon X1300 Series " = R481_ENU, PCI\VEN_1002&DEV_7140
"Radeon X1300 Series Secondary" = R481_ENU, PCI\VEN_1002&DEV_7166
"Radeon X1300 Series Secondary " = R481_ENU, PCI\VEN_1002&DEV_7162
"Radeon X1300 Series Secondary " = R481_ENU, PCI\VEN_1002&DEV_7160
"RADEON X1600 Series" = R481_ENU, PCI\VEN_1002&DEV_71C0
"RADEON X1600 Series " = R481_ENU, PCI\VEN_1002&DEV_71C2
"RADEON X1600 Series Secondary" = R481_ENU, PCI\VEN_1002&DEV_71E2
"RADEON X1600 Series Secondary " = R481_ENU, PCI\VEN_1002&DEV_71E0
"Radeon X1800 GTO" = R481_ENU, PCI\VEN_1002&DEV_710A
"Radeon X1800 GTO Secondary" = R481_ENU, PCI\VEN_1002&DEV_712A
"Radeon X1800 Series" = R481_ENU, PCI\VEN_1002&DEV_7100
"Radeon X1800 Series " = R481_ENU, PCI\VEN_1002&DEV_7109
"Radeon X1800 Series Secondary" = R481_ENU, PCI\VEN_1002&DEV_7120
"Radeon X1800 Series Secondary " = R481_ENU, PCI\VEN_1002&DEV_7129
"Radeon X1900 GT " = R481_ENU, PCI\VEN_1002&DEV_724B
"Radeon X1900 GT Secondary " = R481_ENU, PCI\VEN_1002&DEV_726B
"Radeon X1900 Series " = R481_ENU, PCI\VEN_1002&DEV_7249
"Radeon X1900 Series Secondary " = R481_ENU, PCI\VEN_1002&DEV_7269
; Hanamichi Edit Above
If anyone wants to try the edit, feel free.. I need to setup my X1900 rig, might take a week.
It's probably going to fail don't get your hopes up and please contribute with better ideas.
Usual use at your own risk of various unforseen hazards; smoke, fire, unexpected FPS boost etc.
Cheers
    C7_30314.INF.rename.ini
    52.57 KiB
    32 downloads
    INF file for X850 series with added cards
Reply 1 of 6, by The Serpent Rider
Or someone can make new driver from scratch by using Linux open ATi drivers as draft.
Reply 2 of 6, by BitWrangler
Might need this at some point, had x1300 and x1600 at one time, though they're not showing their faces right now. I coulda sworn I had a box for pre-unified shader PCIe cards.
Reply 3 of 6, by mockingbird
This won't work.
The X1000 generation is a new design, and the old driver won't know how to talk to the chip.
That makes options 1 and 3 (which are essentially the same...) a no go.
And option two has never worked for anyone. NT drivers don't work on 9x, and vice versa.
(Decommissioned:)
Reply 4 of 6, by libv
The Serpent Rider wrote on 2022-01-23, 11:37:
Having written the actual open source driver for R5xx and above, and having spent a lot of quality time with win98SE, and its DDK recently, i can wholeheartedly say: NO!
I should first get my flashrom patches, which adds flashing support for all affordable pci-e devices, up to date and get them committed. If there's anything i should do with R5xx, then it is bring it up natively on coreboot.
Reply 5 of 6, by libv
mockingbird wrote on 2022-01-23, 17:00:
Indeed, the display engine was developed from scratch, and beautifully designed, sadly it got buggered when ATI decided to save on development costs by having the BIOS people and driver people be the exact same team. The 2D and 3D engines were continued from the R3xx, and this 3D engine is still a fixed pipeline design.
Fun and games with VXDs and their insane calling conventions, and their arcane APIs. You would not wish this stuff on your worst enemy.
Reply 6 of 6, by The Serpent Rider
Which overall was normal for DX9 hardware and could be worse (cough cough G70).
Not sure about that being so bad. R520/580 had hidden deep voltage tweaking for different rails "on-the-fly", plus RAM timing editor, which was bananas for that time period.
