First post, by theoakwoody
I just picked up an ibm of jr and would like to be able to play some dos booter games on it. My favorite is the black cauldron and I own it for dos and apple ii but not the booter version. Is there an easy way to take a booter disk image and copy it to a 360k disk? I apologize if this issue has been brought up before as I tried searching but didn’t see anything specific to my question.
I’ll be playing games off a hard drive as well but would love to be able to play games off floppy as well.
Reply 1 of 4, by konc
Well the minimum you need is a PC with a floppy drive, the disk images and software to write them to disk.
If you don't have other old PCs and provided that you have a way of transferring files to the jr, you can even use that to write the images.
You just need software that works on the jr, I'd put my money on ImageDisk by Dave Dunfield or DskImage by M. Brutman.
Keep in mind that disk images for booters not always come in the standard .img raw file that the above programs can write. Some have been made using Teledisk to preserve more data about the image and I don't know if Teledisk can run on the jr. I'd also bet that some cannot even be written back using a normal pc floppy controller, but don't worry too much about them they probably are only a handful of titles.
Reply 2 of 4, by thepirategamerboy12
Dskimage works great for me.
Reply 3 of 4, by theoakwoody
thepirategamerboy12 wrote on 2022-01-31, 01:02:
Great I’ve been trying to use imagedisk. Is there a specific disk image format you use when writing to a disk? I have a 486 with a 360k drive I’m using to write to disk.
Reply 4 of 4, by thepirategamerboy12
theoakwoody wrote on 2022-01-31, 04:38:
To write a 360k .IMG floppy image to an actual disk, type: dskimage filenamehere.img 0:40:2:9. Replace that 0 in the beginning with a 1 if the 360k drive is drive B:. You can also swap the positions of the filename and floppy drive sections of the command to make images of 360k disks.
