First post, by Jed118
- Oldbie
So today I decided to replace the very broken SIMM sockets in my AWE 32 (I had already replaced three ripped out caps and a mangled joystick port - this card has been through hell) and I mostly succeeded, burning only 2 traces (which I bodged, no biggie, they were going from bank 0 to bank 1 on the same pins) BUT the biggest problem is pin 26 - in removing the solder, I had a lot of trouble, and it seems I removed the pad entirely. There's nothing for the solder to hold onto, the pin is just in the hole.
Before
After
Here's the problem, maybe:
Pin 26 is burned out, but the other pin 26 up top is OK. I ran a multimeter to check continuity from the top one, and it doesn't go anywhere at all on the board (I tried most of the close by ICs) - most of the other pins do register some kind of continuity. On a SIMM itself, pin 26 goes to a chip:
However:
It says Pin 26, 28, and 29 ar enot connected on non-parity SIMMS.
Can someone confirm that Pin 26 doesn't connect to anything on this AWE, or at least doesn't use parity? I may have just gotten very lucky if so!
(Edit - actually, in documenting what I'm doing, I decided to check pins 28 and 29, and they are also unused (no continuity anywhere) . Nothing to do now except plug it in and do some testing with the RAM, something I'd have to read up on as I've never loaded sound fonts before)
What's for sale? my eBay!
