First post, by Cyberdyne
Does anyone know, what MP3 bitrates and formats does original Winplay3 support? I like to convert some of my music to listen in my Windows 3.1 retro computers. But modern MP3-s do not play for some reason, and I converted some audio files with Audacity to different variants of MP3, but nothing works.
And maybe someone knows what are the differences in Winplay3 versions 1.0 2.0 2.3beta.... and so on.
In the old days I used Winplay3 to play 128bkps files with my 486 and it worked perfectly.
Reply 1 of 8, by Stretch
Check if the working mp3 have a xing tag. Did you create the old mp3s with audio catalyst?
Edit: The Xing/Helix MP3 encoder may be worth a try.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 2 of 8, by Cyberdyne
I do not have any old mp3-s available that i used to have in the nineties and early 2k. And that time i used Napster. Never heard of xing tag.
Reply 3 of 8, by Stretch
I believe Audacity uses ffmpeg or LAME.
The Xing/Helix MP3 encoder was popular in the 90s in Audio Catalyst, but now Xing/Helix is opensource.
Also various FhG, which you can use when you export a wav to mp3 with Windows media player or virtualdub if I remember correctly.
Reply 4 of 8, by Yoghoo
I used foobar2000 a couple of weeks ago to convert some files to mp3 to test Winplay3 on a 486/66. 128bkps was a bit too much though. It played fine with a little lower bit rate (96bkps?).
Reply 5 of 8, by Stretch
With WinPlay3 16-bit 2.3b5 in Win 3.11 dosbox-x, I was able to play FhG, Helix, and LAME mp3s encoded at 128 CBR, 44.1 KHz stereo properly.
Reply 6 of 8, by Jo22
Ah, I remember WinPlay3!
If memory serves, it didn't support midern ID3 tags properly?
Originally, ID3 tags were added to the end of the file, but this was bad for streaming (web radio).
So ID3v2 moved the tag to the beginning of the file (header).
Having both tags works, too, doesn't it?
Reply 7 of 8, by RetroGamer4Ever
It can play 192khz/44.1, though I suspect that it isn't VBR-compatible.
Reply 8 of 8, by Cyberdyne
Ok. I ask, I answer. I used LameXP batch conversion program. Stripped ID3 tags. And it even plays low bitrate and variable bitrate by the way. Even Windows XP can run Winplay3. So the problem seem to be those modern ID3v2 tags. Original ID3 tag is supported and it even shows the information in Winplay3.
