First post, by Sphere478
Has anyone been able to accomplish this?
A few of us have been trying on the Tyan s1564S/D but as of yet, no joy. 🙁
New clock gen for tyan s1564d (Research)
There are a few other boards out there though. (Dual CPU Socket 5/7 Boards ) But the only other fully featured 430hx that comes to mind is the ga-586DX
As of yet I’ve not seen anyone who has one that was able to overclock it.
Has anyone EVER been able to overclock a dual pentium? On any board? Ideally, a 430hx, but any would be cool to see.
The boards that I’m aware of with 430hx and dual are
Tyan S1564D
Gigabyte GA-586DX
Soyo SY-5TH0/SY-5TH2/SY-5TH5
And this amazing thing Bitchin' dual p-pro setup
Sphere's PCB projects.
Reply 1 of 6, by dionb
There's also the Asus P55T2P4D
When you say "overclocking", do you mean specifically the FSB >66MHz, or does jacking up the multiplier count too? Pretty sure I did the latter back in the day on on aforementioned board, running 2x P200MMX at 233MHz.
Reply 2 of 6, by Sphere478
dionb wrote on 2022-02-14, 00:13:
yeah, I mean fsb greater than 66mhz
Oh cool, lemme look that one up!
Reply 3 of 6, by majestyk
The GA-586DX is quite a petulant board - even when it´s not overclocked.
I never managed to accomplish a stable WIN2K install. As soon as more than 2 PCI/ISA cards are present, you end up in IRQ-hell due to the onboard SCSI controller and poorly documented IRQ/INT routing.
But even when you solve all these issues the board still acts "nervously". I suspect the onboard L2 cache chips are operating at their limit under 66MHz FSB.
But I was successful installing NT 4.0 with a minimum setup: PCI SCSI controller, ATI 7500, 3COM ISA NIC and 256 MB RAM. As soon as you add (ISA) sound, you run into problems.
This system has been my (fun-) FTP-server for over a decade until today. I recently even moved it to a nice new case.
Reply 4 of 6, by Sphere478
majestyk wrote on 2022-02-14, 06:37:
The GA-586DX is quite a petulant board - even when it´s not overclocked. I never managed to accomplish a stable WIN2K install. […]
Did you try xp sp2/3?
Reply 5 of 6, by majestyk
Yea, even tried XP (without ACPI), but this OS is far too demanding here. I think the board was designed for NT, it´s running it very responsive and fast.
Reply 6 of 6, by rmay635703
Too bad the Pentium 266mmx chips can’t be made to work in a dual board
