First post, by Harry_Grunge
- Newbie
I bought a brand new Logitech F310 for my Retro WinXP Machine and it was a bit janky to get working. I'm already used to playing with a Regular Xbox 1 Controller that I use on my Modern Laptop.
I learned about Dinput and Xinput, and I'll list a few things I'd like to know
(1) After Installing Logitech Profiler Version 5.10.127, I wasn't able to open it if my controller was set to the "Xinput Setting" Is this normal?
What I did was install an Xbox 360 Driver for Windows XP and was able to use the Xinput Setting that way. But I'd still like to know if there's a solution to the Logitech Profiler Issue
(2) A variety of games play well with either Dinput or Xinput. However instead of manually switching from Dinput to Xinput by toggling the switch of the Controller, I want to.. I guess "emulate" One or the other. Ex: I wanna keep the switch of the Controller set to Dinput and be able to play an Xinput game with Xinput Settings. Is that also possible??
Again, just some tips to get the best experience from this Controller.
