First post, by Kahenraz
- l33t
I replaced all of the capacitors on a vintage Slot 1 montherboard with genuine Nichicon capacitors which I ordered from Digi-Key. While the system appears to work, I have since found that it is unstable when doing an ACPI shutdown or reboot from Windows 98/ME.
The symptoms are that the system will shutdown and turn itself off when "shutdown" is chosen but "reboot" will hang on a black screen with a blinking cursor, requiring a manual reset. Both options result in the system starting up with Scandisk after detecting an incorrect shutdown (even though it appears to shutdown correctly when this option is chosen).
The strangest behavior is that if I use the power button instead of the reset button when the system is hung on the blinking cursor, it will NOT turn back on and appear "dead", even if the PSU is toggled on and off and the power cable is reseated. To revive the board, I have to have the PSU off and hold the power button to drain the capacitors. Only then will the system turn on.
I chose these capacitors specifically because of their brand name and low impedance but I wonder if the fact that the HV(M) series capacitors, which the datasheet says has a +/- 20% tolerance has created this issue.
I don't know if the motherboard had this problem before the recap as I hadn't performed this exact test. It's an uncommon model and I've never been able to find an exact replacement to confirm how it previously performed stock. I have many vintage motherboards, but this is the only one that I've done a full recap of all of the large 470uF capacitors.
The motherboard is a Shuttle HOT 675V with a VIA VT82C691 Apollo Pro chipset. I am using the latest BIOS version 675VS026 available from Shuttle.
Does anyone have any thoughts on this?
