First post, by Lycanthropist
Hi!
The sound card is detected by Windows 98 and I am able to install drivers, but the device manager signals a resource conflict. Looking a the device resources, I can see the following:
- Interrupt Request: 00
- Input/Output Range: FFFC - FFFF
- Input/Output Range: FFFC - FFFF (Yes, the same range a second time)
- Input/Output Range: 0000 - 0003
The last one is marked as having a resource conflict with the DMA controller. None of these parameters look right, though.
A second CT4760 and an SB0060 (Soundblaster Live! 5.1) show the same problem. All of them work fine in an AMD K6 computer.
The BIOS has a function to assign an IRQ to a specific PCI slot. I tried all of the available IRQs but this didn't help.
I also tried putting the sound card into a different PCI slot, but nothing changed.
Has anybody ever seen something like that? What can I do to use the sound card?
