First post, by JK1984
I was hoping to get get some info/opinions. I managed to get my hands on a copy of ACERCPR - Hard Drive Recovery Kit. Looks like its version 1.11. A bit older than a few versions I have seen floating around on the internet. I have two Acros's - two different models. One is the exact model (4221g) I had while growing up. The other one (P433D) is a bit older. The 4221g looks like it has a rather old install from the original owner (which I backed up) I was hoping to restore the 4221g to the original factory install with this CPR Kit.
However I'm not sure which Acros model numbers go with this CPR KIT. While poking around on the CD I saw 12 different archives, which are 12 different drive images. I don't see any information on which model number these correspond to. There also is a folder labeled "ORIGINAL" that includes setup disks for Windows 3.1 and Dos 6.2. Including all drivers and for each software title so you can pick and choose what to install one at a time . I made a floppy disk image and had to edit the config.sys and autoexec.bat on the included bootable floppy to get the recovery software to recognize the CD-ROM drive. Since I had to do this it makes me think that the CPR Kit that I have isn't exactly what I need, but it seems rather close! I'm rather hesitant to actually go through with the recovery software.
I guess long story short, what would you do?
    1.44 MiB
    866.44 KiB
    1006.8 KiB
Reply 1 of 5, by Horun
Hmm do you have the original 2X cdrom in the machine or is it a newer one ?
Reply 2 of 5, by JK1984
Horun wrote on 2022-03-09, 01:17:
It's the original. 2x, Panasonic 563 with a sound blaster card. I remember my system coming with Encarta 94. I just realized this recovery kit has Encarta 95. So it may be a few months/year newer than the system I have.
Reply 3 of 5, by Horun
Can you image the CD + floppy and post to Google drive, Archive org or some other place ? Would be nice to have a copy 😀
Reply 4 of 5, by JK1984
Horun wrote on 2022-03-09, 02:04:
Yeah, i'll get it uploaded in a bit. I was poking around some more and it defintely does seem like this CPR Kit is for their early Pentium systems.
https://books.google.com/books?id=yurvRCerf_U … acercpr&f=false
Reply 5 of 5, by JK1984
JK1984 wrote on 2022-03-09, 02:20:
EDIT: here is the CD and Floppy images. https://archive.org/details/img-7067_202203
