First post, by Harry_Grunge
I'm currently building a Retro Windows XP Gaming PC, here are my specs:
CPU - AMD A8-6500 APU with Radeon(tm) HD graphics
Memory - Kingston 4 GHZ DDR3 1600 MHz
1 TB Seagate Driver
Windows XP 32bit SP3
I have games ranging from 1997 - 2009
I've been looking for a great GPU, and I recently had a choice of choosing between a GTX 460 and a GTX 680. I chose the 680 due to the 460 having the awful Fermi Architecture.
I know it's overkill, but I thought I'd give it a try
I installed driver 340.52 and I'm facing issues with running a lot of older games.
Here's what I see when I run NHRA Drag Racing 2:
The attachment dragster 2022-03-10 21-59-49-57.png is no longer available
The attachment dragster 2022-03-10 22-00-00-67.png is no longer available
I'd like to find a solution as soon as possible, I can try to return the GPU back and try something less powerful. Should I downgrade the driver? Should I use older hardware?
Reply 1 of 7, by BitWrangler
I was reading somewhere the other day someone saying NHRA DR2 gets corruption on Geforce 6x00 series upwards, and one either had to use an older card or a glide wrapper.
Reply 2 of 7, by Warlord
Trying to run old games on that hardware you're asking for all kinds of trouble. opinions on great GPU vary. I wouldn't consider anything newer than a ATI X800 or Geforce FX5900 great at any old games. Those are about the highest you can go without running into problems.
Reply 3 of 7, by Harry_Grunge
Warlord wrote on 2022-03-11, 04:47:
What Should I do? Should I Downgrade to a different GPU? I can try to get a GTX 200 Series Card from the same place I got the GTX 680 from
Are there any solutions with the current hardware that I have?
Reply 4 of 7, by Warlord
you should try a glide wrapper.
Reply 6 of 7, by Harry_Grunge
BitWrangler wrote on 2022-03-11, 04:46:
Shit really? Had no idea that was an issue, I appreciate you letting me know. Any Glide Wrappers you can recommend for WinXP 32 Bit?
Reply 7 of 7, by Warlord
nglide. is your best bet.
