First post, by aigeek
Hi, I'm rebuilding the first generation Pentium 4 system. luckly I just spent $10 to get an ASUS p4t-e motherboard. Of course, this motherboard was marked as no POST, but when I got it, I realized that the PWM IC of CPU had been disassembled for repairing, but the work seem not completed and leaving several blank positions. I don't know the accurate spec of the six missing PWM ICs. If anyone happen to have this motherboard, I hope you can help check the BOM:
Q11
Q12
Q13
Q14
Q15
Q17
The attachment P4T-E_Blank.jpg is no longer available
The attachment P4T-E-mark.jpg is no longer available
Reply 1 of 4, by PcBytes
Q14 appears to be a 50N03 or 60N03 (whichever will work, one is 50A and the other is a 60A) according to this pic I found on Imgur
Q12 and Q11 seem to be the same so that leaves you with Q13, Q15 and Q17.
Reply 2 of 4, by Dorunkāku
Q11, Q12 and Q14 are marked 50N03A.
Q13, Q15 and Q17 are marked 14N03L.
Good luck with the repair.
Reply 3 of 4, by aigeek
Thanks pals, a new hope ahead ^&^
Reply 4 of 4, by karakarga
Q11, Q12 and Q14 are marked 50N03A. 50N03A (GeneralSemiconductor) --> 30 Volt, 78 Amper, 70 Watt
Q13, Q15 and Q17 are marked 14N03L. 14N03L (Infineon) --> 30 Volt, 30 Amper, 75 Watt
