First post, by dreamblaster
Releasing another new project : CrystalBlaster C2, based on CrystalBlaster C1
C1 was a through hole solder kit, this is a completely soldered, mostlySMT PCB version.
It has a 90s low end wavetable synthy sound, as it uses the Crystal CS9236 chip.
Available at https://www.serdashop.com/CrystalBlaster-C2
CS9236 specifications :
- General MIDI (GM) compliant
- 32-note polyphony at 44.1kHz rate
- Independent reverb and chorus levels for each MIDI channel
- 128 melodic instruments and 47 percussion sounds
Transport Tycoon Deluxe demo : https://youtu.be/PVQcIlXb5S0
Warcraft II - Orc 1 GM demo : https://youtu.be/miT54jRpUag
Thanks for your support !
