First post, by Sosowski
Hi!
I've been wondering if it is possible to create a Socket 3 transposer that would allow a 14x14 PGA-132 386 to be plugged into a 17x17 Socket 3 486 motherboard.
I've seen ideas for solutions that go the other way round, since nobody in their sane mind would want to put a 386 on a perfectly fine 486 mobo back in the days, but I'm thinking of building an ultimate 386 machine running on a newer 486 chipset with 256MB RAM support, etc.
Wikipedia lists some SiS, Ali ,VIA , and UMC (can't fine the site) chipsets as supporting both 386 and 486 and having both a PGA-132 and a Socket-1/2/3, making me think that all of the chipsets that can be cranked to 5V would be able to support a 386 and they just lack a socket for it.
Sounding like a fun project, I am thinking of trying to design a transposer / adapter to put a 386 into Socket 3, but wanted to ask if this is viable or are there any possible pitfalls for this? I mean, Socket-3 is 168 pin, that's 34 extra pins, but most 486 CPUs don't use the outer pins anyways. I'm also wondering if the lack of on-chip cache would be a problem and if it would require slapping a SRAM chip on top of the adapter to account for it.
One way or another, I have not seen a ready solution for this and wanted to ask whether a project like that would be viable enough to give it a shot.
Reply 1 of 10, by Anonymous Coward
I have actually seen a photo of an adapter that has an am386DX-40 that plugs into a PGA-168. I think it was posted on VOGONS in the last year. That adapter is made for a specific motherboard though, and I'm pretty sure you'd need to change a few jumpers to get it going. I believe the chipset was in the OPTi 495 family (a hybrid chipset).
Any kind of passive adapter isn't going to work on a regular 486 board.
Reply 2 of 10, by Deksor
I'm not so sure. I have a hybrid board (that doesn't work unfortunately) and it seems that all the pins that exist on the 386 side also exist and in fact are connected to the 486 side. I think the 386dx shares a lot in common with the 486. This needs more testing, but I'm really curious about this. Running a 386 on a late 486 board could bring some interesting results and perhaps let people do some crazy overclocking (66MHz 386DX on a PCI board with Edo ram ?)
Reply 3 of 10, by Anonymous Coward
TI486SXL (a 386 bus compatible CPU) comes in both 132 and 168pin packages. The two chips are functionally identical, with pretty much all of the extra 36 pins not connected to anything. The 168-pin version is not compatible with standard 486 sockets though, and requires a special board to get it running. I would guess if it could have been made a drop in part, TI definitely would have gone that route.
Reply 4 of 10, by rmay635703
Anonymous Coward wrote on 2022-03-21, 14:43:
Pipelining, burst, sequential read/write, cache, multiplier pin, bus cycle, timing
Are all different or not present on a 386, unless the chipset is designed for the slower 386 bus it’s unlikely you could get a 486 to communicate with a 386.
http://www.pchardwarelinks.com/486pin.htm
Reply 5 of 10, by Deksor
No that's the opposite we want to do. Run a 386DX in a 486DX motherboard, not run a 486 in a 386DX board.
Reply 6 of 10, by jesolo
Why not track down one of those hybrid 3/486 motherboards that supports both CPU's?
You can then swop out the CPU's as you desire.
I have two of these type of motherboards and most of these were based around the OPTI495 chipset.
Reply 7 of 10, by imi
I have this adapter, I can't tell if it will only work on specific boards/chipsets though as I have not yed had time to try it out.
the way it's constructed it doesn't fit on a lot of boards though.
but seeing that such a thing clearly exists, the chances of success are there ^^
76.27 KiB
Reply 8 of 10, by mR_Slug
I would say this is doable. You wouldn't *need* to add SRAM as cache. I remember reading about 286 to 386sx adapters being made with just a few PALs. The interfaces are different but not too dissimilar.
The Retro Web | EISA .cfg Archive | Chip set Encyclopedia
Reply 9 of 10, by BitWrangler
jesolo wrote on 2022-03-21, 19:33:
One that I have got is SiS and Contaq, center board in this pic download/file.php?id=115198&mode=view
Reply 10 of 10, by rmay635703
Deksor wrote on 2022-03-21, 19:01:
I know
but the issues for a 486 into a 386 are solved by an off the shelf transputer module
While the other way isn’t solved
The 386 into a 486 are the same problems as your chip is missing features and compatible timing a true 486 board will require but no “transputer “ module was made to put an older 386 into a 486 board
