486 hard drive on dos 7
First post, by andy120
im having trouble getting a 486 to use 32 bit partition. it sees the cf card as 2 gig correctly and fdisk can only see 512mb. 32 bit is enabled in the bios. with 98 or dos 7 installed it will not read the hdd and either system halts or no os errors. 6.22 fdisk only seems to have fat16. i cannot use a floppy and have been loading from another pc on dos 7/w98. i have a isa i/o card but i do not know how to enable the floppy port without getting an error from the (missing) onboard fdc. options?
Powered by one Harris 286-12
Reply 1 of 3, by waterbeesje
Bios limits, probably the system is not set to handle LBA. If it can at all, as many 486 some sort LBA at all.
Stuck at 10MHz...
Reply 2 of 3, by andy120
So, i have got LBA to work on a D drive (fat32) but if i put that drive in C it will give me no rom, system halted. LBA is enabled. could there be something that it can only boot to a fat16? there is no specific 13h.
Reply 3 of 3, by waterbeesje
Did you recreate partitions and format the cf under DOS? Also you could try the "fdisk /mbr" switch to (re)construct the master boot record.
Most cf are not directly suitable for bootable DOS partitions, so they have to be set up right.
Stuck at 10MHz...
