First post, by chris2021
I was told a long time ago (~2000 A.D) that when working inside a computer, pull the power cord as their are "low" voltages travelling through the board/s. This was.opposite to my practice until that.point, as I would leave the power cord connected so I could touch the case and discharge any static buildup.
So ... is this a feature of modernish atx type hardware? Do consumer grade computers have standby power for whatever reason (servers from at least the late 2000s positively do). I guess all atx power supplies have a 5v standby rating.
If a hardware manual tells you to unplug the p/s's before removing cpus/ram, can it be assumed that unit has standby power in at least some sense?
