First post, by Kerr Avon
When I print photos at home, I just use the print function from Irfanview, a good, well featured picture viewer. But I've never bothered to look into the subject of maximizing the quality, and the 1:1 colour/brightness/whatever quality of the input .jpeg file to the final printed image. So I was wondering, is there any advantage to using different software, say something that specialists in printing (and is preferably either free or not too expensive)? Could something like this potentially improve the printer output? Are there any settings in a printing program that I should know about when printing, or anything I should do to the image file first?
Of course, the quality of the printout is ultimately limited by the printer, and my printer (an Epsom inkjet) does a good job already, and if I wanted better then I'd probably just get them printed out at Tescos. But does anyone have any tips or advice on improving the visual quality of printed photos, please?
Reply 1 of 4, by cyclone3d
Take all photos in RAW.
If you must save to jpeg, then save at 100% quality after processing the RAW image.
In-camera conversion to jpeg leaves much to be desired.
You will also want a high color gamut display and a screen calibrator.
Then you will want to color calibrate your printer after having color calibrated your scanner with special software and the special color calibration sheet that goes along with it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by Kerr Avon
cyclone3d wrote on 2022-03-31, 22:52:
I just use the program 'A Better Camera', on my Samsung mobile phone (I don't have the soul of a photographer!), and it doesn't seem to have a RAW setting.
I can do that, thanks.
OK. To be honest, I don't want to spend a lot of money (or time) setting up things. So instead of buying a hardware calibration device, and especially not a new montior (I like the one I have now ;o) ), would any of these websites be good for calibration:
https://www.makeuseof.com/tag/5-online-tools- … ibrate-monitor/ ?
I haven't scanned any photos in, so why would I need to calibrate a scanner? I would have thought that a scanner was (or at least could be set so, at the factory when it was made) automatically set up to read the colours of the scanned material as correctly as the hardware allowed?
Since you obviously know your stuff, what software do you use to print, please? And what differences are there between different types, or manufacturers, of printer paper? I use matte photo quality paper.
Reply 3 of 4, by cyclone3d
The reason for the scanner calibration is because to calibrate the printer, you will need to scan the test prints back into the calibration software.
I wouldn't trust any website or other monitor calibration software that doesn't use a hardware device to look at the screen during the calibration.
There is absolutely no way to calibrate a monitor properly otherwise. And those devices can also be left plugged in to adjust the screen based on ambient light.
The goal is to get prints to come out as close as possible to what you are seeing on screen.
I don't generally make photo prints at home because it is so much cheaper to just pay to have them printed so not sure about what paper is best for that.
Really any good photo paper should be fine.
What is the brand/model of your current monitor?
YMF7x4 Guide
Reply 4 of 4, by Kerr Avon
cyclone3d wrote on 2022-04-01, 15:14:
I see, thanks.
Yes, I couldn't think how, without a separate, physical, pre-set colour chart/gadget/whatever, it would be possible to accurately judge the monitor's colour accuracy when using a website, or a purely software solution.
Have any hardware manufacturers ever attempted to create a standard, so that all of their monitors, printers, etc, are all calibrated to the same standard? I've never really considered it before, but modern TVs come with lots of options for altering the colours and shades and contrast etc, but I've never seen an option on a TV called "Aut0-calibrate the TV output to the Industry Standard Visual recommendations" or "Set All Options to the Video Output Standards (c) 2015" etc.
Yes, I usually get the local supermarket to print them out for me. I was just idly wondering how to get the best from my current home setup, though I'm sure commercial printing will always be better quality (at least when you only have a reasonably priced printer at home).
An AOC 27B2AM. My current printer is an Epson EcoTank ET 1810.
